Originally Posted by speedyspaghetti
Good ideas - thank you very much for the effort you put into your post... really helpful.
Do the brake/clutch fluid requiring bleeding? Or are they self-bleeding systems?
The brakes and clutch both require bleeding. Neither is hard if you use a Motive type pressure bleeder. The clutch slave bleed valve is a little tough to get to...you kind of do it by feel and a lift is a tremendous help.
