You probably want to do 1, 2 and 3 all at the same time while it’s up on the lift Just went to purchase Koni FSD dampers (4) for $804 on line. Replacing the dampers will take all day on the lift. You will have to remove the front brake calipers to replace the struts. So you might want to do that work while it’s torn apart.
2004 Boxster S
