12-20-2017, 04:07 PM
#10
Originally Posted by speedyspaghetti
Hey guys,
I posted on here a while ago about some vibrations/judders I was feeling through my steering wheel that a few shops had been unable to diagnose. I took the car (2002 Boxster S with 85k miles) to a highly recommended Porsche specialist here in the Bay Area and he did a thorough - and I mean painstakingly thorough - inspection of everything the car needs. He scared me a bit with his list - I don't think he's suggesting I do all of it, but he said he could find $15k (!!!!) worth of stuff to do.
Here are the main things he mentioned needed doing - just hoping you guys could share some insight on fair-ish costs, just to make sure he doesn't try to screw me. His labor charge is $200 an hour, so I might not do everything at his place, but I'll probably have him do a couple of things. He said he'll call me tomorrow with some numbers.
1. He thinks vibration is caused by inner/outer tie rods and possibly strut mounts.
2. Rear passenger strut is leaking, suggests replacing all 4
3. Rear trailing arms need replacement according to him
4. Clutch and/or shift cables need to be replaced - this is the one that has me a little miffed. I did notice that the clutch was starting to get a little hard to push in, but it does not slip at all. Shifting into 2nd has been a little jerky recently, but I figured that it might be something to do with not having had the clutch fluid changed and I have no service records from the previous owner indicating that the fluid was changed. I probably won't have him do this one since he didn't say it's an immediate necessity, but I also don't want to risk damaging the transmission itself.
He mentioned other things like coil packs, spark plugs, and window regulators, brake pads and rotors, but I'm pretty confident that I can do those things myself.
Thank you guys for any insight you can shed on any of the above items.
If you feel it thru the steering wheel 1st stop is a good wheel balancer that can remove wheels & test balance on a spin balancer.
