Old 12-20-2017, 08:10 AM   #10
seningen
seningen's Avatar
Originally Posted by heiwaz View Post
- Yes, the big shift selector (gearbox) that moves shifter front to back (copkit) moves correctly.
- Yes, I detached both shift cables from gearbox
- My gearbox is mounted in the car, this picture is the same as my gearbox.
I have disassembled several times the transaxle to change clutch, IMS,.. and never have any problem when disconnected the cables, no need to adjust.
When the shift get blocked was when I was driving the car and try to shift gear.
I moved the large lever and it moves correctly, I feel the clicks. But..., the small lever doesn´t moves, and don't feel any click, so the problem is inside the gearbox.
Yes, I think tha need to open the gearbox. Sorry for my english language, I try to write I best I can
Now I have the car elevate to start to take out the gearbox and open it.
One or more of your shift pins may have fallen out -- this happened on my 2000 S that I track a lot.
These are not the large pins that go through the case -- these are very small pins that are part of the shift rods? (I maybe misnaming the pieces)
I had the tranny case opened up and all 6 pins replaced -- works fine now.
Mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
