If the window is at the wrong angle, it will bind on the seals. Did you mark the locations of the original before you pulled it out? Try loosening the bottom connections and the pinch clamps. Then finesse it a bit and see if it helps. Did you have the same problem before the part swap? Did you get the stops in the right locations? I had a small learning curve until I got it right.
