Old 12-15-2017, 11:28 AM   #10
Boxstard
Maybe you install that lighter battery you got and see if it makes appreciable difference to you. If not, probably you won't notice much difference moving it down to the frunk floor and you can prioritize other things.
I like the way it is installed, protected from impat and weather. With 914 they installed it in the engine bay half exposed to the environment so it spits acid right over the longitudinal frame to corrode it.
