Old 12-15-2017, 09:33 AM   #22
rick3000
There Is No Substitute.
rick3000's Avatar
Here's a copy of the blueprint I made. The only tweak I would make, would be to make them a bit longer and use 2x4 instead of 2x2 for the ends. I predrilled the holes to avoid splitting any of the wood, and put 2 screws into each side of every board. They weight a lot, but you could also add some metal handles and edges if you wanted to get fancy.
