Originally Posted by itsnotanova
This only works on base models and not the S because the third radiator is in the way. There are holes on the bottom of the bumper cover. If you reach up toward the right side of the car you can grab the cable and yank.
Will try that out, this one is a base. Thanks.
Originally Posted by deathsled986
Good luck with your flood Boxster! I picked up a flooded 01 S out of Miami just recently. Water only got high enough to kill the immobilizer. Sadly the ignition had already been changed once and the door lock had been drilled out, so getting a key from Porsche didn't do the trick. Ended up getting a good deal on ecu, immobilizer, ignition lock, door luck, and 2 keys from eBay. Checked all the fluids, charged the battery, and it fired right up!
Wow I didn't even think about looking on eBay for a set. There is A LOT of them on there! Thanks for the idea.
