Good luck with your flood Boxster! I picked up a flooded 01 S out of Miami just recently. Water only got high enough to kill the immobilizer. Sadly the ignition had already been changed once and the door lock had been drilled out, so getting a key from Porsche didn't do the trick. Ended up getting a good deal on ecu, immobilizer, ignition lock, door luck, and 2 keys from eBay. Checked all the fluids, charged the battery, and it fired right up!
