Originally Posted by Rav 986S
Does anyone know what this fitting kit looks like and if I need it to collect? If I need a kit, where can I buy this? In the UK they seem to be around £100 - $135.
The spinlocks and shoulder bolts required look like this:
Your Boxster may already have them, so it would be wise to check before you buy a set. They are available from the dealer, eBay UK, and possibly any dismantlers in your area. While it is possible to transport the hardtop on your Box without them, I wouldn't recommend it. Why risk breaking the front latch? You may consider buying a latch cover also:
Installing the spinlocks can be quite stressful, because if you slip up, you could lose the shoulder bolts in the chassis. A detailed installation description can be found here:
https://www.renntech.org/forums/topic/8854-installing-spinlocks/
Good luck with your purchase!
Just sayin'..............
TO
