Old 12-09-2017, 12:58 AM   #11
rusty69911
is a cradle really needed? I am going with factory mounts as its only 100hp increase, that way you only need to fabricate an adapter to the front mount, I am going to modify the side mounts to allow a bit more exhaust clearance too, on the engine side I am removing the AC and PS pumps so mount bolts on there and then on the other side I am going to use the original Audi brace arm and also bolt through to the block in at least one place. I am using a GM astra electric power steering pump up front.
rusty69911 is offline   Reply With Quote
