Old 12-08-2017, 09:03 AM   #2
cas951
A bit pricy but a very clever solution.
That’s what I though at first but after using them a few times and see how it made the work so much easier was well worth the cost. Specially when you have to raise the stands higher.
Just to put the Boxster in Jack Stands alone is quite a bit of work, if you have to raise the car really high you would think twice before doing it. With the liftbars It makes it so easy to raise the car as high as you need it to go as long as your jack stands are high enough to support it. If not this my next choice would be quickjack.
2008 Boxster S PDE2
02 Boxster S Blk on Blk(Stock for the Wife)
88 turbo S (My Toy) slightly modified
cas951 is offline   Reply With Quote
