Old 12-07-2017, 06:32 AM   #11
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by titaniumdave View Post
... planning on using the 6 speed 986 trans and cut it to clear the starter of the Audi motor. Anyone done this?
What clutch did you use for your build?
I'm currently building with a 986 5-speed and a flywheel/clutch arrangement for an Audi A6 2.7T (C5 platform). I may pull my 6-speed off the Boxster engine in a week or two and get a look at if there are any issues using the 6 speed transmission with that clutch and flywheel. I'll post if I do.
What engine are you using, 32 valve or 40 valve?
I ran into an unexpected problem with mine, where after I bolted the transmission on the engine wouldn't turn. My clutch pressure plate was in contact with the transmission housing. I'm currently waiting for a "01E103551H" spacer to correct it. Most swaps have not needed it and I'm still not sure why mine did. I'm using a late 2003 AUX engine and I don't see other swaps with that particular one.
An Audizine thread about the spacer: http://www.audizine.com/forum/showthread.php/766013-Audi-Engine-To-Transmission-Spacers-Function-When-Are-They-Needed
Here's some clutch and flywheel discussion that should be helpful (also mentions spacers): http://www.audizine.com/forum/showthread.php/508044-V8-Models-What-Flywheel-And-Clutch-Combo-Are-You-Running
