Old 12-06-2017, 11:06 PM   #6
particlewave
If the axle bolts were installed correctly then there is no reason to not recheck torque, especially for the first time DIY'er. As long as you check to the original torque value there will be no additional movement. However if it does move then they got loose for some reason , dirt, corrosion or incorrect tightening sequence etc. and you will be thankful for the chance to correct the problem.
I checked mine about a week after i C/O the output seal and again when I installed the Koni FSDs. No movement either time. Bonus tip: This task is made especially easy with a 3' extension.
Aside from the linked post below, I read on another forum specifically to use medium thread locker and leave them be because trying to tighten again could weaken the thread locker. I can't find it now, but I recall it being a reputable source (possibly JR).
Help removing cv joint bolts
particlewave is online now   Reply With Quote
