Wild Horse Pass West Track
Was out at WHP west track this past Sunday with PCA Arizona and it was a blast! The weather was perfect and I set a personal best time of 1:10 on session #3 with the DE3 group. This is a 1.1 mile short and very technical track with just one straightaway. Good for wearing out tires
Here's the video. I tried zooming in on the oil pressure and temp gauges, but the resolution is not very good. You can still see the Accusump light when it activates.
https://youtu.be/MpEnfEvDRug
Next week I should be installing my AutosportLabs RaceCapture Track and AnalogX module so I can wire up and log the oil pressure and temp, as well as the Accusump air pressure and maybe even the actual brake pressure (or I could do the Accusump oil pressure after the filter but before the cooler). I'll be at AMP on Dec. 16th with Pro Autosports.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
