Old 08-22-2006, 09:19 PM   #3
MNBoxster
Hi,
While conceptually anything which forces more Air into the intake will work, there are no free lunches.
A Standard Supercharger has some issues, mainly Turbine inefficiencies, and it is tied in some way to the revs of the Crankshaft and creates a Parasitic Loss of Crank Horsepower.
As an example, the Supercharger on the Jaguar XK8 draws 76 HP at full boost, but it raises power output by 100HP doing so. Now, if you had an electric SC which required 76HP worth of Amps to operate at full power, it'd take considerably more than 76 Crank HP to produce those Amps by the Alternator.
The problem with the electrics is that Electric Motors are limited in their power output/size. That is, it takes a pretty big motor to make more than a couple lbs. of boost, usually too large for the engine compartment. So, anything which does fit, is going to be limited.
And, while the Elec. Supercharger does not draw Crank HP, the Alternator which powers it does. And, these inefficiencies are compounded - those of the SC along with those of the Alternator. Now, there is a formula for the Amps needed to power the SC motor and one which determines the Parasitic loss at the Crank by the Alternator to produce those Amps, but it's late and I don't have all the necessary variables to do an actual calculation.
One of the advantages to Alternators over the previous Generators is that unless there's a demand, the Alternator almost Freewheels, that is draws minimum Crank HP. But, once there's a heavy demand, the Alt. draws Crank HP much greater than the load requires due to it's inefficiency. Much of this Crank energy is lost as Heat. Also, there's a limit to the number of Amps the Alternator can produce, and to save fuel, Manufacturers don't usually oversize them by much. So, with accessories, AC, Lights going, charging the Battery, and such, there may not be enough Amps left to power a SC anyway.
I'm afraid in the end, this device won't live up to it's claims and so is essentially a waste of money. Hope this helps...
Happy Motoring!... Jim'99
