Thread: Engine Sensors
Old 12-05-2017, 08:56 PM   #11
mnc-i
Gelbster
I am quite sure that I did not miss connect the coils.
I followed the same method/system I've always followed when changing spark plugs...change one at a time before going to the next plug & coil.
I had the issue of a severe rough idle, backfires and engine dying out on me prior to me changing the plugs & coils.
Codes P0154 & P0134 are pending codes and somehow are linked to the Pre-Cat 02 sensors.
Code P0410 is for secondary air injection.
Code 1124 is for fuel pump rely output stage
Code 1126 is for Oxygen sensing adaptation, lower load range cyl 1-3
Code P1411 is for secondary air injection system, cyl 4-6
Code 0455 is for fuel tank ventilation system major leak
MNC-I
mnc-i is offline   Reply With Quote
