Old 08-22-2006, 05:57 PM   #13
JackG
[QUOTE=GrizzlyThat's not correct. The boulevard rule takes precedence. Even if you were going 250 miles an hour, backwards, with your lights out, the car that blew the stop sign and entered your path when you had the right of way is at fault...at least in the eyes of the law. I agree that the family could attempt to use the information that you were over the speed limit to sue you for the death, but you would not be cited for the accident.[/QUOTE]
I was stating what could happen. You sure that'll always be the case? Right now it can't be proven easily or at all if the car having the right-of-way was speeding, but once it can be, things may change. Besides your example, as colorful as it was, is surely not correct. If the law doesn't cite that guy for the accident, we've got bigger problems than black boxes, eh?
After all, the "boulevard rule" fails when the driver in the right fails the sobriety test, right? Is it such a far reach from drinking to speeding? Maybe 4mph over is OK, but 5mph over earns you vehicular manslaughter. Even when it is truly unavoidable no matter if the speed is 55 or 60, and the other person is totally at fault.
Point is, it is a slippery slope, and once we've started down it, there's no going back. Also, you seem to be on the enforcement side of things... is that tainting your opinion? Anything is OK as long as your job is easier?
We still have the right to be judged by our peers... not by some black box without the ability to think or reason. I'll hack or disable it any way I can. I'm sure the big brother "do-gooders" will pass a law against that as well.
Jack
2000 Boxster S - gone -
2006 Audi A6 Quattro 3.2
JackG is offline   Reply With Quote
