Old 12-03-2017, 07:08 AM   #11
Anker
Annual maintenance. Yesterday I drained the transmission fluid and today I will fill it with fresh fluid and then reassemble the braces that needed to be dismantled for access. But before that I'll inspect the sway bar bushings for wear.
I discovered that the battery maintainer was toast when the battery ran low. Fortunately I have another that I soldered the cigarette lighter plug to and it is working. Hopefully the battery didn't get damaged from getting run down.
Next project to tackle is cleaning the radiators and replacing the frunk latch. I'll also reroute the emergency cable to the tow ring location.
1941 Dodge Luxury Liner Coupe
