Old 12-02-2017, 05:34 PM   #9
Boxstard
Originally Posted by DWBOX2000 View Post
Do i loosen the sway bar from the link or from the two bolts that I believe screw into arm mount? Both wheels are up off the ground. I removed the three nuts from the strut mount. It dropped about an inch. Do I loosen sway bar on both sides on just right. Should I let the right suspension hang or relieve some weight by jacking the wheel carrier support up a little. Thanks for your help.
Let both ends hang free, then just disconnect the sway bar from the drop link on just one end. I did replace that rubber gasket this year, be careful how you orient the plastic spring seat that the gasket fit, mine was not aligned properly and it took some try &error.
