Old 12-02-2017, 02:42 PM   #8
DWBOX2000
Do i loosen the sway bar from the link or from the two bolts that I believe screw into arm mount? Both wheels are up off the ground. I removed the three nuts from the strut mount. It dropped about an inch. Do I loosen sway bar on both sides on just right. Should I let the right suspension hang or relieve some weight by jacking the wheel carrier support up a little. Thanks for your help.
DWBOX2000 is offline   Reply With Quote
