So many questions to your questions.
Overflow is through a hose in FRONT of RR tire. The reservoir you replaced leaks in the trunk which will empty through the air circulation vent opening in the right corner of the trunk, this appears BEHIND the RR tire. So question one is did you use a Genuine reservoir or something aftermarket and Two did you use Airlift to fill system or purge properly?
