Old 11-28-2017, 08:50 PM   #8
mikehkang
BTW, I should add that my problem was the headlight switch. More precisely, internal build up of "something(carbon?)" inside the switch.
After pulling off the side vent and the switch from the dash, I applied generous amount of contact cleaner through the middle of the shaft while holding up the switch shaft side up. I then reinstalled the knob and turned to all the switch positions, including the fog light, like a mad man.
I then removed the knob, apply more contact cleaner, reinstall the knob, turn to all switch position then repeat the steps for about 4~5 times.
The switch works now.
Thank you again particlewave.
mikehkang is offline   Reply With Quote
