Here is some more info. If the car is running, everything works fine door, windows, top. If the car is off with key in ignition, I need to pull the door handle a number of times before it will open. Sometimes it will simply not open. As I mentioned below, when I pull the handle, the window drops as normal even if it won't unlock. Any guidance?
