Originally Posted by Brad Roberts
You'll be disappointed **somebody sucked you into that deep sump. The 2.5's have nowhere near the issues the 3.2/3.4/3.6/3.8 M96 and M97's. The 2.5 spins 1k less RPM and doesn't fill the heads with oil as bad as the engines I mentioned above. CA Speedway (with stock pan and X51kit) drops from 60lbs of oil pressure in the banking to 20lbs....... for 50-60ft at 130+mph. Next track that we have oil pressure *drop? Chuckwalla. Guess which corner? The banked corner. For 30-40ft. 60 down to 30. Who cares. LOL The engine will run for several minutes with no oil pressure.
Brad, I was at Chuckwalla last week. Reviewing my in car video, I did not see my Accusump trigger in the 10 deg banked turn. That would suggest no less than 35-40 psi, at least for my setup. Of course, I wasn't running at extreme cornering Gs either, maybe 0.9-1.0 Gs. I do run the EBS oil baffle (X51 type) with a 2 QT Accusump and the 35-40-psi system, with Mobil 1 5W50 oil.
Here's the link:
https://youtu.be/KaEAu7W8_bM
Thre's an orange LED (to the left of the dual gauges) that comes ON whenever the accusump dumps. I does come on occasionally on turns 9-10, 16.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
