Old 11-26-2017, 06:18 AM   #11
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by DWBOX2000 View Post
Now the eccentric bolt is on the track arm right? That shouldn't be so bad to loosen. I will mark and loosen. ...
The info you need for the eccentric bolts is in this post including torques:
Replacing the rear suspension bracket
Any suggestion on how to torque? Can I put the torque on the Allen wrench and just a wrench on the nut. Hold the Allen in place and turn the nut with the wrench? Would it still click?
Without removing the strut, I don't think you are going to be able to do a proper torque. Probably the best you can do is estimate. Here's what my old shop manual has for strut torques:
