Old 11-26-2017, 05:31 AM   #1
DWBOX2000
Thanks for the replies. I have a small noise in the rear right quarter when the car moves. I jacked up and shook everything around. The only noise I got was when I put a 2x4 under wheel and I bounced up and down. It might also just be the sealing ring. It wasn't in the best of shape when I put the car strut back in the last time. I remember thinking I should replace. My gut is the mount is good. The car only has 53k on it and doesn't appear to have had a rough life. Now the eccentric bolt is on the track arm right? That shouldn't be so bad to loosen. I will mark and loosen. Any suggestion on how to torque? Can I put the torque on the Allen wrench and just a wrench on the nut. Hold the Allen in place and turn the nut with the wrench? Would it still click?
DWBOX2000 is offline   Reply With Quote
