Changing the regulator requires some adjusting after the fact. There are height adjustments that are accessed from the bottom of the door, thru ob-round rubber caps. You also need to reprogram the top and bottom of the travel. This requires running the window up to stop and holding the button for 5 seconds, if I remember correctly. Followed by running it all the way down to stop and holding for 5. I had to fiddle with mine a bit, to get them to work correctly. The Pelican link is very helpful.
