Thread: Help with CEL
Old 11-21-2017, 06:52 PM   #1
boxfix
I had the same SAI code problems.
I found that the check valve on my 2003 had fallen out of the rubber manifold. I fixed this with a brass barged fitting that I plugged into the rubber manifold and they used a piece of high temp silicon tubing to connect it to check valve.
I also found that the vacuum reservoir was leaking. This is a common problem. I tested the installed reservoir with a vacuum pump and gauge. It would not hold vacuum. A new reservoir is a little more than $20. I installed a new one and hooked up a vacuum gauge to the system and pulled 16 Hg to 19 Hg. Which is good and where it should be.
With these fixes my vacuum problems were cured.
2003Boxster
1973 Carreras RS tribute
2000 Saab Aero wagon stick
1990 Chevrolet pu pre runner
boxfix is offline   Reply With Quote
