Old 11-21-2017, 07:39 AM   #1
dsallean
New shifter cables and short shifter
I had an issue not to long ago with the end of my shifter cable coming loose and only having 1st, 3rd and 5th. Fixed the cable temporarily and bought a new set of cables to install. (I would rather fix it properly instead of the jeri-rigged, silicone, fix-it job I did to get it working.)
I also have Ben's short shifter installed. Will the neutral alignment tool work with the short shifter? I thought I read somewhere that it might not. If not, how does one get it set up properly? Do I need to reinstall my old shifter with the alignment tool then transfer the markings over to reinstall the short shifter?
Thanks in advance.
Dave
dsallean is offline   Reply With Quote
