Originally Posted by zvovchik
Forgot to ask, what tire pressures are we talking about if going squared? Maybe i try put my existing 255 AS/3 up front and install new RA1 in the back for starters. Existing as/3 are fairly new and i live in portland OR, so im trying to have wet weather capability..back to pressures....What would be reccomeded?
Im thinking as/3 fronts would offset the grip with RA1 in the back. Am i tottaly wrong here?
Completely incompatible tires. Your car would push like a pig all day.
Maybe choose some middle ground and mount RE71R on all 4 corners. This is a fast tire that works street or track. Almost as fast as RA-1 but works better on stock suspension. You will still toast the outer shoulders but a better fit than RA-1 tires.
