Old 11-19-2017, 09:48 PM   #1
martsink
Timing 360 Degrees Off. What is the quickest way to correct?
Hey Guys,
I need help with the most appropriate and fastest procedure to fix my mistake. I was replacing a bad lifter on bank 4-6, but I set the engine to the wrong TDC (the index cam was pointing outward instead of inward). I only realized when I put it all back together and went to check the timing.
What I was thinking of doing is:
- Remove the 4 bolts on the exhaust cam sprocket (see below) to allow it to rotate 360 degrees
- Undo the chain tensioner to relieve some pressure from the sproket
- Lock the cam in position with the cam holding tool
- Rotate the engine 360 degrees
- Check the timing (should be correct now)
- replace and torque the 4 bolts on the exhaust cam sproket
Edit: this is a 5 chain engine
Let me know if I'm missing something or if my procedure doesn't make sense.
Thanks!
martsink is offline   Reply With Quote
