Old 11-18-2017, 03:51 PM   #3
particlewave
There are most likely intermittent codes. Clear them and see if they come back.
Sounds to me like the car thinks the passenger door is open. Likely a bad switch in the door latch mechanism. You said you replaced both, but are you sure they were both good? What about the door harness connectors in the door jambs (corrosion, bad connection)?
