Old 11-17-2017, 04:47 AM   #2
Lacostas
Originally Posted by edc View Post
So if the water didn't pass the sill where did t come from? The main cause for water behind the seat is the rear drains or holed foam tray. The fact you said it was raining heavily also lends weight to this being the cause. If you can feel the water atop the carpet then the foam insulation underneath will be much wetter.
Well the water didn't come in from the side (doors) but it did come from the bottom of the car, since I guess the bottom of the car is notsupposed to be 100% sealed and waterproof ?
Plus the rear bottom carpet ( closest to the firewall ) got wet on both drivers and passengers side. I have already checked the only drain hole I know ( which is under the roof plastic on the drivers rear side) and it was Clean
How and what else shall I check ?
Lacostas is offline   Reply With Quote
