So if the water didn't pass the sill where did t come from? The main cause for water behind the seat is the rear drains or holed foam tray. The fact you said it was raining heavily also lends weight to this being the cause. If you can feel the water atop the carpet then the foam insulation underneath will be much wetter.
Current: 550 Spyder Anniversary- Carnewal exhaust - 100 cell cats - stainless manifolds - 4" underdrive pulley - poly gearbox mounts - rear lower alu brace - adjustable rear toe links
Sold: 986S - Zenith Blue - 18" Sport Classics - Black Zunsport grilles - Stainless silencer and manifolds - K&N panel - shortshift - M030 suspension - 75mm throttle body - custom 83mm intake - SmartTop - custom remap - MDS underdrive pulley
