Old 11-16-2017, 01:43 AM   #4
RobertKing
Originally Posted by Jgkram View Post
Nope, no rocking and the wheel isn't locked. It's always been a little difficult to turn but in could weather, at times, it feels as though I could snap the key off in it, it's gotten so stiff. This was the primary reason I changed out the electrical portion of the switch last week. Thanks for the response. I may take it to a locksmith or may try what some have suggested online which is to flush the lock through the key slot with lots and wd40 and then lube it up, again through the key slot with the Triflow PTFE lubricant. I'll let you know how it works out or if I'm riding with Urber for awhile!
Don't use WD40. Use lock lubricants. WD40 dries out and becomes sticky. Use light machine oil instead.
RobertKing is offline   Reply With Quote
