Old 11-15-2017, 06:14 AM   #7
emore93
Don't mean to add to the confusion but...
I thought 97 - 00 were different than the 01 - 04 clusters?
You should be able to look at the back of the cluster to determine if it is similar.
The 01-04 (if I remember correctly) white, green, and blue connections while the 97-00 are white, black, and blue.
I did a 996 swap and it was basically plug and play. Everything worked fine but the miles.
I went ahead and had it changed over to the correct miles and VIN (just because I am anal about those things) but it was working without changing any of that.
I have an 01S that I put 02 996 cluster into.
emore93 is offline   Reply With Quote
