Originally Posted by dghii
+1
Assuming you bought OEM equivalent sensor so no funny business with the part,
What was your prior code? You have 4 sensors.....the two rear ones won't generate a code IIRC.
If its the same code as before, get under the car and reseat the O2 connector.
The prior code when my original sensor put the CEL on was something like "sensor not responding quickly enough"
My car has 2 sensors 1 on each side (UK)
Same code different comments.
Thanks for your response.
