I put a little heat to the carrier with the torch and struck the bolt a few times with a hammer. It came out with difficulty using an 18" snipe. The carrier will need a helicoil but at least I can save it. I also found that the rotor was loose because both screws had been sheared off at some time. Its got the same Textar pads that I bought. Are these OEM?
__________________________
'58 356A coupe, just a driver
'00 Boxster S fair weather - daily driver
'11 Jeep Grand Cherokee Limited - winter daily driver
'92 F250 - junk hauler; previous Porsches '95 993;'08 Cayman S;'70 911E
