Old 11-12-2017, 09:08 PM   #12
RobertKing
Originally Posted by 1096369fred View Post
Hey Starter986, I don't mean to jump your thread..... But since your sorted out.....
I'll try the opening and closing trick.... Couldn't hurt ! But I forgot to mention.... My driver's side window isn't dropping when the door is opened or closed.... And the remote keys don't work.... (One lights the LED one does not) And since I just bought this car Friday so don't know it yet..... I figure it can't hurt to ask.... So purhaps it is a switch or sensor that is bad.... Was going to pull the door card and try the cable tie trick.... But maybe there is more to my issue!
Thanks!
Fred
Stick the key that does light the LED into the driver side lock. Lock/Unlock the car. Enter the car, place the "working" key into the ignition switch. Start the engine. Shut it off. That key should now be enabled. The other, check the battery in the fob. If it's weak or dead, that could explain why you get nothing at all from it. It could also be faulty switches in the fob. Just so you know, these fobs are automatically disabled after a week or so of disuse.
RobertKing is offline   Reply With Quote
