Old 11-12-2017, 09:12 AM   #2
Ciao
Ciao's Avatar
You can certainly DIY. I have replaced the boots on 2 cars, one a tip and the other a 6 speed. The parts are cheap, it's mostly a labour intensive job. Be prepared to get dirty and make sure you have everything that you need before starting. You don't need to remove the complete axle, just the inner flange. However, if you do decide to remove the axles, it will be easier to work on.
Hmmm. What do I need in terms of tools?
5280 Cruising @High Altitude
Seal Gray & K&N Filter
