Old 11-12-2017, 08:18 AM   #10
Starter986
1998 Boxster Silver/Red
Exactly. A Cable operated system. Now they're both "locked". Zero give. I'll try the cable route you suggest.
However... who can explain why both would lock at the same time AND after an otherwise incidental coolant dump?
Thank you.
FIXED!
The link provided helped. I remembered that the driver door had to be opened for the actuator to allow the lever to be pulled up (can't unlock trunk/frunk with door closed). So, I figured maybe a switch wasn't recognizing that the door was open. I opened and closed the door several times, with some encouragement... then locked/unlocked 4 times.
Opened the door... pulled the lever... BOOM. Opened.
The only bummer is that I should have checked the lever after first opening/closing the doors several times... and before the lock/unlock method. One of them worked.
Thank you, people. This board is an invaluable resource. And on a Sunday morning, nonetheless.
Surely I'l be back as I go investigate the dump.
Cheers!
