Old 11-11-2017, 09:37 AM   #13
Ciao
Ciao's Avatar
Originally Posted by Boxster-Tiptronic View Post
Excellent results with 4 styrofoam plates 1.5 in thick during winter sleep.
Prior to roll the Boxster onto the plates I pump the tires to 60 psi.
When starting up in spring, reduce the pressure back to normal and you will drive away with perfectly "round" wheels.
Best Cost Effective solution seen!
5280 Cruising @High Altitude
Seal Gray & K&N Filter
