Old 11-11-2017, 07:40 AM   #12
Boxster-Tiptronic
Set tire pressure to 60 psi and put wheels on styrofoam
Excellent results with 4 styrofoam plates 1.5 in thick during winter sleep.
Prior to roll the Boxster onto the plates I pump the tires to 60 psi.
When starting up in spring, reduce the pressure back to normal and you will drive away with perfectly "round" wheels.
Boxster-Tiptronic is offline   Reply With Quote
