					Originally Posted by ohioboxster
				Wow, I hope your right! What happened? What did the car do or not do?
This is still the P1502 code (Throttle Spring).  Since the '00 model is eGas, the throttle spring is not in the engine.  I replaced the throttle body and a couple of other things before getting to this, but no change.  I called the "experts" at my local dealer and asked if they have to calibrate the throttle body with the PST2 and the answer was "my shop forman said we
might need to do that, just make an appointment".
At least if this takes care of it there will be a cure for others instead of two months of figuring it out or a few thousand dollars at a dealer doing the same thing.
