Old 11-11-2017, 03:37 AM   #6
RobertKing
Originally Posted by aussieboxy View Post
Started he up this morning & drove her out the garage to do some work on her.
This afternoon:
1) Ignition on all good battery ok.
2) Turn key & nothing. No dimming of ignition lights.
3) Won't roll start
4) Drivers side window stays extended when door open
5) Checked all relevant fuses & all ok
6) Removed battery terminal for 5 mins & reconnected...no change.
Got me stuffed atm
Are you depressing the clutch fully in neutral? If not, she won't crank. My 2001 Boxster S does this if I don't push the clutch all the way down.
RobertKing is offline   Reply With Quote
