Old 11-11-2017, 12:13 AM   #5
particlewave
You'll need to disconnect the battery to unbolt the seat and visually check the immobilizer and its fuse. If you do find signs of water damage, you'll need to find a repair shop in the Land of Oz or ship it off to the US (ECU Doctors, $500-ish for the repair).
Another possibility is the ignition switch, which is a cheap and easy fix. You should probably order or pick one up from your local auto parts store so it can be eliminated. It's a 10-15 min job and they run about $20 in the US.
It should probably be replaced either way as it is low cost and a common point of failure.
