Old 11-08-2017, 10:20 AM   #16
rick3000
There Is No Substitute.
rick3000's Avatar
Putting the Front on Stands:
-Use the factory rear jack point and lift the entire side of the car up
-Use the alternative jack point that is forward/inside the factory front jack point
Putting the Rear on Stands:
-Use the factory front jack point and lift the entire side of the car up
-Use the alternative jack points under the suspension
-Use the alternative center jack point under the engine to lift the entire rear up (requires a long/low jack)
Front and Rear:
-Use a grooved jack pad on the unibody seam a few inches forward or back from the factory front/rear jack points (I do not recommend this because the unibody seam will probably bend, but it is only a cosmetic issue)
