Old 11-08-2017, 11:17 AM   #10
kk2002s
kk2002s's Avatar
For the front if you look back on this thread you will see pictures indicating a frame structure at the back of the tire about a foot in from the edge. I use a small piece of 2x4 between the jack and the sub-frame. I place my jacks just behind the front tires, enough so you can get the stands in after jacked up. I jack both sides, a little bit on each side, until the car is high enough to place stands under.
Seal Grey
