When lifting the front of a Boxster, is there a single point in the front you can lift the entire front end that is well clear of the two front jack points?
If so, where is that point?
The idea would be to lift the front end at this point with the lift in one area, and then be able to place both jack stands and lower the car evenly onto them.
Can this be done?
